Hi Guys,
I seem to be having a problem with my Potterton Puma 80 heating water when the burner is not actually on! Any ideas?
I have noticed over the past few days a strangle bubbling sound from within the boiler (sounds like boiling water) and a hissing/spluttering/gurgling of very hot water escaping from the auto airvent valve (looks like a car tyre pressure cap) at the top left of the boiler. This is usually when I get home from work after the boiler being unused for 8-10 hrs, or 1st thing in a morning, when again its been unused overnight!
Previously when first drawing water from the hot tap it would be lukewarm for the few seconds before the burner fired up - which I assumed was residual heat, but now when you draw HW its absolutely scalding hot as if its been sat "boiling" away in the boiler all day long.
Surely the pilot light cannot have anything to do with the water getting this hot can it? Thats the only source of heat I can find as its definitely not the burner (even left the boiler in standby to test that theory today!!)
I have recently had an engineer out for a separate problem where the PCB & Fan were replaced, but now I have the new problem of extremely hot water (when I didnt ask for any!!), and not knowing much about boilers I dont want to come home one day to find my boiler has exploded (or something along those lines....)
Any info/ideas would be greatly appreciated!
Mike
Mike
