Hi can anyone help me???
I have a fairly well used potterton puma which seems to have adopted this dreaded overheat cut out problem they tend to develop. I had a plummer out who replaced the thermocouple and overheat stat - no joy, I replaced the flow microswitch which was sticking slightly and also the automatic air vent which was leaking, but still have problems.
The boiler works fine if it's just central heating, or domestic hot water you're after on their own. The problem is that if the central heating is running and then hot water is used for a prolonged period (ie to run a bath while central heating is switched on) the boiler cuts out on turning off the tap. It always lights easily afterwards, but does require manual re-lighting. It's definitely not the flow switch, flu, pilot, thermocouple, fan, overheat stat, or pump so to be honest I am left wondering what the hell it could be?????
All other times it works fine it's just in this particular instance.
Any help would be greatly appreciated.
