Boiler is a Potterton Puma 80e Combi
Got up this morning to no DHW or CH and the Low Pressure light on the boiler lit up. Checked the gauge and it was down near zero.
Just had some plastering / decorating done with a few rads being taken on and off so presumed the system hadn't been topped up afterwards.
Anyway filled it up to just over 1bar but the low pressure light stays on. So whipped out the multimeter and found that the CH pressure switch is staying closed regardless of the pressure in the system (took it to about 2.5 bar).
With the switch disonnected the boiler works fine on both CH and DHW. It is also holding pressure fine.
I'm thinking perhaps some crud got in the system with the rads being on and off and bit of it is stuck in the switch. Can the switch be stripped and cleaned or should I just buy a new one (only about £20) to be safe?
If I keep an eye on the pressure gauge is there any problem using the boiler until I can get a new switch on Monday?
I'll drain it down fully when I do the switch and give it few fill / run / drain cycles before inhibiting it to get any other crud that may be in there out.
Graham
Graham
