Hi all,
Question for all the knowledgeable one's on here! Have a Puma 80e, turned on CH, boiler went thru the start-up sequence fully, fired up, then after about 30 secs it shuts down, with a sort of kettling noise coming from the pipe coming down from the heat exchanger, pump making a gurgling noise and very hot....
I assume that the overheat stat is kicking in and turning the boiler off as I leave the controls set to "On" calling for the CH. After about 7/8 minutes the boiler again goes thru the start-up sequence, relights for 30 seconds then turn's off again
Any Obi-one Kanobi's out there that can help me pretty please The DHW works fine by the way......
Cheers, in anticipation ...
