I hope someone on here can help!!! Ppppplease.
I've just moved house last week and the problem is as follows. The flat has a Potterton Puma 80e Combi boiler.
The hot water through the taps has absolutely no pressure. The Pressure gauge is reading below 1 bar and only just above the red zone for the low pressure light. Hence absolutely no pressure!
I've opened the refill loop and basically the water just runs directly out of the over flow pipe straight out of the wall and onto the garden!
Also when you do try to refill, the system bangs away like theres no tomorrow and does so for about 5 seconds after you turn the water off.
Please help, I'm desperate for a decent bath!!
