potterton puma
6 Jan 2010
Glasgow
hi everyone i hope someone can help me with this i have a potterton puma boiler and my hot water isnt that hot,the dial is turned up to the max is there anyway i can turn it up manualy ?
Wait for the outside Temp to rise..Your incoming main is pretty cold at the moment.
check that someone hasn't knocked the gas tap at the meter making it partially off. Not enough gas would give those symptoms.
Perhaps you are expecting too much.?
Your boiler will only heat about 8 litres/minute.
Try reducing the flow rate!
Tony
