I have a Potterton Statesman oil boiler using its integrated stat for temp control.
The boiler fires up as normal as far as the stat is set below half way (unfortunately not hot enough to heat up the house in cold weather). If the stat is set above half way, the overheat light (red one) lights up the first time the boiler is asked to fire up (cold burner, lights up even before it tries to fire up!).
If a reset the boiler using the small reset bottom under the control panel, it starts up and I will usually have another red light at some point after heat up the water and will no longer allow me to reset until the boiler has cool down a bit.
My suspicion is that I have two different problems, one at firing and another for overheating.
Some facts to consider:
-Tank currently around 25% full
-No room stat available
-Boiler serviced last August
-Pump noisier the usual but seems to work
Any advise on the above will be greatly appreciated. I am currently on visit 3 from local engineer with no success so far. It has been suggested the spark control, control box or stat as possible issues but it would be great to have your thoughts on this.
Many thanks!!
Al
Many thanks!!
Al
