potterton suprema 40 problem
1 Jan 2005
no hot water and boiler would not fire up unless i pressed reset button but ihave a sound like kettle boiling/bubbling sound from boiler is this serious problem what do need to do or get done
thanks for any help
and make sure there's water in the header tank above the feed pipe.
Recheck pump - feel pipe a couple of feet on from the pump - is it hot?
Could be air trapped - look for an air bleed point by HW cylinder connected to pipes fom boiler, which go into the side.
The problem is the PCB (printed circuit board). Its a very common fault in this boiler - and it seems that Baxi Potterton have made a lot of money from selling these boards, which should be under a warranty anyway.
They cost anything between £150 -£250 +vat
Or the better option is to get a reconditioned card(£40 -£50 + vat) from a specialist.
I am just about to use a company in Watford but I have not got their details to hand.
when I find them i will post themon this board.
I jumped the gun a bit there on my previous note, (not reading all of the notes.. silly me), of course this will not cure circulation problems.
Hi, SPS Plumbing - did you find the details of the company in Watford that can supply recon PCB's? I also have a Suprima cutting out...
Thanks.
Thanks.
Have an ideal place in Watford
David
