Potterton Suprema 40....
21 Jan 2007
Fife
Went to a relatives today as she had a problem with her boiler, the boiler was cutting out intermittenly sometimes running for 1-2 days then she would re-set it but still same problem would occur, she moved into the house last year and there is no instructions for the boiler, it is a balanced fan flued potterton Suprema 40......my query is there is no expansion vessel or gauge so 1 assumes there would be a safety expansion pipe leading up into the small header tank for the heating but alas there is not 1, checked around house & in loft for pipe potruding out roof.....am I missing something here,shouldn't there be one?? There is a cylinder in cupboard upstairs along with pump & 3 port mid valve, checked them & there all functioning ok, think it could be the PCB......but the expansion is confusing me :confused:
Combined feed and vent into system would only require the one pipe.
And yes its does sound board related.
But there is no 'open' vent just feed......am I getting you correct?
The expansion of hot water would just expand in system therfore causing overheating wouldn't it?
As long as the feed pipe is 22mm then its a combined feed and vent. The expansion is taken up by the tank, same as a conventionally piped feed and vent.
