Hi. Can you help. I have a potterton suprema 50 boiler. keeps going on lock out . Told to change pcb and over heat + thermister. Fine ,now it works better,i just have to reset it every 8to9 hours instead of every 1to2hours , can anyone give me a solution.
Could be the pump now playing up, circulation must be there as your rads are all ok ?. So as the o/h stat was changed, the old one may have been cutting in alot earlier than needed
