Hi There,
I have a Suprima 30L, which is approx 3 years old, & was working fine. One month ago it started playing up in the really cold weather.
If you have hot water selected on with CH selected on, no probs, hot water gets very hot & rads get nice & hot too. Problem is, when hot water tank hot gets to temp, boiler cuts out (even when room still below thermostat temp).
If you select CH on only, the boiler tries to fire up, fan runs, but after a minute or two, flashing red light comes on, fan keeps running.
Have had circulation valve & motor replaced by heat team engineers (grudgingly). I have been advised a power flush is required as there is a blockage in the pipework.
I have a good engineer coming tomorrow to diagnose the fault which he believes is either a controller fault or wiring fault as he insists it can't be a blockage (& I believe him).
Has anyone come accross this / got any ideas what the problem could be. If you run the fault diagnosis it suggests a blockage or a flow sensor, but with two heat team engineers telling me it's a blockage I am confused.
Cheers. PJ
Cheers. PJ
