Hello,
I have a Potterton Suprima 30L CH boiler, works fine when switched on, boiler fires up, ignites and heats water. When the required temperature is reached it unfortunately goes wonky.
The red light is on to signify it has reached the the required temp, after a second or two it goes out and attempts to go through the ignite sequence again which it does but for a couple of times then locks out. Once the temp has cooled down and the reset button is pressed it works fine........until it reaches required temp again.
Any information appreciated.
Cheers
D
Cheers
D
