My suprima 40 went into lock out just as above. It came on at times, then not at all at other times , then only heated water slightly at other times before turning itself off! -Frustraing intermittant problem of the worst kind, I ordered a new pcb from
www.keeptheheaton.com . p/n 5102160 (replacement of old p/n 407750).Funny how potty don't recognise there was a problem with the old part but decide to revise it!!. It cost 130 pounds + vat + 2.50 pounds for delivery(cheapest i could find) .I ordered it over the net then had it delivered the next day-brilliant!. Some addendum instructions were included on how to fit it which it said was in addition to the users original instructions manual.I couldn't find my original instructions manual but in the end didn't need it- cos it was so straight forward to switch the board over anyway. All you need is 2 philips head screwdrivers - 1 small head , 1 larger head . Simply
a) isolate /turn off power to boiler
b)undo the 3 screws holding on the side casing.
c)old pcb board will swing down into view
d)pull off the 2 spades connectors & 5 connector blocks(noting which way round they fit)
e)undo the 4 small screws that hold the pcb to the case and remove it
f) put in new board and affix using screws removed from e)
g)reconnect block connectors. (notice 2 connectors relocate into 2 slightly different positions on the revised board 5102160 -These are the 2 blocks closest to the LEDS on the board- its very apparent where they fit cos they have different sizes so can only fit into their matching sockets! )
h)reconnect the 2 spade connectors
i)Put on new fascia card on panel (new board has slightly different reset button - so needs a hole- the new fascia is provided with hole in it - see the included instruction leaflet to replace old one)
j)Replace side casing of boiler using 3 large screws removed earlier.
Turn power on and watch the boiler spring to life!
Will take you about 1 hour or so at the very most.
Best of luck.+ no more boiler worries - You will have hot water to shave in the morning etc.
SORTED!!!!
