Hi folks.
My Potterton Suprima 50L will not fire and then locks out. When I reset, the fan comes on and I can see the ignitor sparking, but boiler does not fire.
When I check voltage across the wires at the gas valve, between the red and green/yellow wires I see 0v until the ignitor is sparking when I then see 240v, and across the red and black wires I see 160v until the ignitor is sparking when I then see 700v.
I know of the appalling reputation of the PCBs on these boiler, and I'm already on my second, but before I consider buying another one (reconditioned from for £60), does this actually sound like correct operation of the PCB, therefore suggesting that the gas valve has broken? Checking the gas meter, it shows no usage of gas through the 20 or 30 re-starts it's attempted whilst I've been investigating it. Is there any other checks I can do to home in on the problem?
If it's the gas valve I won't be trying to change that myself!
Thanks,
Glenn
Thanks,
Glenn
