Hi my neighbour has this potterton Suprima 50 l controlled by a BP 2000 potterton programer to a Honeywell Y plan with cylinder stat and room stat mid position valve V4073A and of course a wiring centre.
She has only just bought the house and is an old lady on her own.
She was complaining of the rads not getting hot enough, and she was cold.
Being a qualified electrician, and feeling sorry for her, I offered to take a look. I found the system was a Y plan but having printed off the Y plan system wiring it was not wired correctly! I rewired it and also now included
the pump over run wiring and the HW Off wire to the boiler which were not installed directly to the boiler connectors before!
I now find the boiler will start up without the HW or CH being switched on?
On testing it would appear the CH connector on the programer is live all the time if the HW off wire is connected?
Also if both CH & HW is switched on and both stats calling when hot water reaches temperature the boiler starts cycling on and off but only the green LED is flashing every 2 sec and the red LED is off?
I have read lots of threads about Suprima and PCB, also sticking valves?
Is there anyway you can help me sort this for the old lady or do I have to tell her she will have to call in a potterton engineer which I know having just moved and found other problems with the house she can not afford!
Please Help
Johnboy60uk [/b]
Please Help
Johnboy60uk [/b]
