This boiler is approx 10 years old, it has had a replacement pcb (the improved version with black reset switch) a few years ago. When cold the boiler will fire up normally and run for approx 1-2 mins then shuts down, it tries a relight and the burner ignites but the green light continues to flash, it shuts down and repeats two more times before locking out with red light flashing. I'm assuming its not sensing a flame so I've cleaned and checked the contact of the ignitor/resistive wire all OK. Is it likely to be the pcb as many other problems seem to be related to it or have any of you experienced problems with the resistive wire or electrode? Is there a resistance value for the wire that I can check with a meter? Thanks
