Hi All
Newcomer to this board, although I've read plenty of threads re the dreaded Potterton Suprima lock-out problems.
My Potterton Suprima 60 goes through its ignition sequence fine, the boiler starts up, with the flame igniting (while the green LED is flashing fast). Then it shuts off - repeats this sequence 3 times then goes into lock-out. I know the boiler is designed to turn off under certain circumstances, so have replaced both the temperature sensor and the overheat thermostat, still the same behaviour.
More in hope than expectation, I also changed the PCB, with a recon from CET Ltd. (good service by the way). And still get the same.
Not sure where to look next - any suggestions gratefully received.
Cheers
Jimbo
Cheers
Jimbo
