A recently replaced fan for a Potterton Suprima 60HE was working fine for a few weeks but now is shorting out, blowing the fuse.
There is now brown corrosion on the electromagnet part of this new fan.
NB: the old one looked corroded and also gave the same fuse blowing problem and I'm now annoyed that I didn't push the heating engineer to investigate further why that corrosion was there in the first place. I was just grateful to have heat at the time and put the corrosion down to the boiler being 10 years old.
However, now I'm seeing the same corossion on a new (and now also not working) fan, I'm wondering what the problem is.
My suspicion is that condensate or something is dripping back through the cold air inlet on to the fan due to a damaged seal with the inner part of the flue or some form of flue damage.
That's my guess anyway. It's a simple short flue but of course must have some connection from the elbow joint to the short pipe that goes horizontally (but slightly raised) outside.
Is this a common problem or can someone suggest any other possible causes?
Hopefully, the heating engineer will pop round today if he can find a slot in his calendar but in the meantime, I would like to be a bit clued up.
Many thanks in advance.
