Drained water from central heating. Put Sentinel x400 (cold spots in radiators - not air) into FE tank and filled up the system. Switched on boiler. Lockout light - red, Burner light -flashing, Mains light - on. Radiators not heating. Pump very hot to touch. Info on boiler flap says that the sequence of lights means there is a 'Flow Thermistor' problem. I'm assuming that something has happened to the boiler by me draining the water out of the system? Can the Flow Thermistor be fixed by a non-plumber or am I best getting in a central heating Engineer?
