I have a Potterton Suprima 70. The boiler comes on and heats water/rads up as normal. In this weather I generally knock both onto constant. What happens then is the boiler will get upto a certain temp and then cuts on and off. It will run for circa 20 seconds then cut out for about an minute. it will then keep repeating this. The pump keeps running and the rads get cool/DHW will not re-heat. I changed the OH stat in the boiler last year when this problem occured. Someone suggested I may have a bit of sludge in the boiler pipes and this is the cause. Anyone any ideas??
