I'd be grateful for any opinions anyone has on the following problems:-
Potterton Suprima 80 - open system about 9 radiators over a three bedroom flat.
One cold radiator at far end of system - system bled regularly (almost daily at the moment).
Whole system power flushed about six weeks ago (lots of sludge came out). Then the cold radiator removed and cleaned out (lot of sludge still in that radiator).
Boiler continually going into lockout - (sometimes many times a day).
When the pump is set at three the lockout problem is worse the boiler makes alot of knocking noises and the system pumps lots of water into the header tank which then vents water out of the overflow. However some heat does seem to get to the base of the cold radiator.
Pump at two fewer lockouts and less overflow issues no heat to back radiator.
When the pump is set at one the lockout problem is reduced but no hot water reaches the cold radiator and no overflow.
The boiler was serviced about 20 months ago and heat exchanger changed I am not sure if the PCB was changed but the one there is the modern one with the square button reset.
Any thoughts appreciated as me and several plumbers seem to be stumped by these problems.
Rick
Rick
