Hello,
I’ve got a couple of problems with my CH system and would be grateful for your advice. I’ve got a 5-6 year old Potterton Suprima 80 system boiler feeding 16 radiators and a 210l Megaflo. There have been no previous lock-out problems.
Towards the end of last winter the boiler over-pressurised and vented on a couple of occasions. I assumed this was due to overheating caused by sludge building up as one of the radiators was taking longer to warm up than the others and the bottom of the radiator remained cool, so I increased the pump speed and that has kept me going ok up till now. Four weeks ago I added a litre of X400 and today attempted to flush the system.
I ran the boiler briefly this morning, turned it off at the mains, drained it down and flushed it through. I then topped it up, ran the briefly boiler again and repeated the process and finished off by adding 1l of X100. I then re-pressurised the system, switched it back on at the mains and tried to run the boiler. I set the programmer to run and turned the room thermostat up to call for heat but the boiler refused to light. It ran through the lighting sequence three times then locked out. I’ve tried using the reset button and turning the power off and on several times but each time it locks out after three unsuccessful attempts to light.
Can you please suggest what could be causing the lockouts?
Also, there is an automatic air vent on the primary return out of the Megaflo. After re-pressurising the vent is now continuously dripping water. The system was only re-pressurised to its original pressure of 2bar. Any suggestion why it should leak now? It has never dripped before.
