- Joined
- 22 Dec 2012
- Messages
- 2
- Reaction score
- 0
- Country
I have a holiday house fitted with a potterton suprima boiler and a roomstat. When I last visited I noted that the Central Heating hadn't been working and that the roomstat had stopped clicking. I checked he power supply to the roomstat and then replaced it with a new one which seemed to work OK, but the boiler shut down soon after firing up and showed a red lock out light. At this time the radiators were still cold but the DHW cylinder was hot. I called a CH engineer who suspected the PCB without investigating further and then briefly looked at the motorised three-way valve in the airing cupboard but I am not sure whether he did anything to it. Howevem the CH then started working. The CH Engineer seemed to think it was a faulty diverter valve and left having promised to come back in my absence and change it. After he left the CH heated up uncontrolled until I switched it off at the control panel, and I once again noted that the new roomstat had stopped clicking. I switched the system off when I left the house, returned home and waited for the CH man to call me to tell me he had changed the diverter valve and all was well. However, when he called he said he hadn't done anything as he had maybe changed his mind about the valve, had noted that the boiler seemed to be bypassing the roomstat, and once again suspected the PCB, but was generally stumped and would speak to Potterton and call me back, which he hasn't yet. Two roomstats failing one after the other seems too much of a coincidence to me and the replacement clicked fine for a couple of hours until the CH fired up. I have no confidence the CH engineer will identify a fix from his present position and am facing the prospect of returning to a freezing holiday house and starting again with someone new. Does anybody recognise these symptoms and able to advise the likely fault?
Thanks chaps
Sophierose
Thanks chaps
Sophierose
