I have just changed my 3 way divertor valve and have drained and cleaned the system using a CH cleaner refilled and bled the system using the radiator bleed valves, HW tank air bleed and pump screw bleed. I have an open vented system with a Potterton Suprima 50L bolier which was installed in 2006 in a new build house.
Problem is on start up and trying just the HW system first the boiler starts but exhibits a green and orange flashing light before after about 10 seconds stopping displaying a red light. If I reset it just does the same. I can hear the pump working but believe it may be an airlock in the boiler as the pilot doesn't even try to light. I have tried what appears to be everything and even tried running heating but still no joy.
Would this be an airlock between the boiler and the pump as I have noticed what appears to be a drain valve above the boiler with a hose connection and a nut and knurled nut fitting on the other pipe but if I open either no water or air flows out so am rather confused.
I was thinking about connecting a hose to the downstairs radiator and forcing water the opposite way to clear an airlock but am concerned this may not work.
Please can anyone offer any suggestions that may fix this problem
Thanks in advance
Dave
Thanks in advance
Dave
