Hi, I've got a curious issue which I have been scratching my head over. Been getting repeated lockouts - orange light flashing, after 4 times solid orange light. Step one of the manual states check condensate trap, which I did and some debris came out, fitted back and the boiler happily went about it's business. 24 hours later, same lockout, emptied condensate trap, a little more debris, when back to normal operation. I've now repeated this process over 4 times, no more debris in the water trap, just runs clear, no blockage in waste pipe, can run water through it.
What I really can't understand is how the air pressure switch, which is the source of the shutdown, can be affected by the condensate level? I need some education. I assume the that the air pressure switch must be some diaphragm that reacts to the low pressure generated by the fan blades blowing air through the fan hood. This air enters the secondary heat exchanger which passes the air out through the vent after removing some of the suspended water particles held in the steam generated by the combustion process. I can't understand how a cup full of condensate water can shut down the system.
Could it be a faulty air pressure switch? How do they fail? Do they just completely fail or do they just start getting temperamental? Also how is it that emptying the condensate trap gives me another 24 hours of boiler operation?
Kind thanks in advance of any replies.
