We have a Potterton Suprima 60 which has had the usual PCB replacement a while ago, but it's now started to make a strange noise (sounds like some sort of internal pump or fan).
Rather than just spending more money on it, I think it'd be better to go down the new boiler route (I think it's about 15 years old).
When the boiler was installed our house was significantly smaller. Since its installation, we've had a couple of sizeable extensions added, hence I feel the boiler is a bit on the small size.
If we were going to replace it with another Potterton Suprima, I'd probably go for the 80, as I think the primaries on the Suprima 100 are 28mm aren't they?
Is anyone able to give me a recommendation for a replacement boiler that will be pretty straightforward to swap. As I say, the primaries on the existing boiler are 22mm, so that will need to be taken into account.
Any help, much appreciated.
