Hi hope you can help i have a potterton suprima 30 boiler, ep2002 controller, ptt2 cylinder stat and a drayton room stat on a fully pumped system. The problem i was having was that when my time clock was OFF the boiler started up on its own , i suspected the clock so i changed it for a new one but it still happened so ive now changed the clinder stat and found out it has a boost button to start the boiler when the clocks off for a tank of hot water, the only problem was that when the boiler started up the pump didnt run so i got 'water hammer' pretty bad and so shut it off. Traced the wiring and found it was completely wired wrong so fettled that but the drawings show the pump connected via the 'pump' connection inside the boiler were as it was wired via just the CH switch before (hence the pump not running when just the HW on) is this right ????should the pump be connect via the boiler ???? ill attempt to upload the wiring pic.
Thx for any help.
Regards Mark.
Thx for any help.
Regards Mark.
