Its started playing up again. A 3 year old boiler and i replaced the PCB last year.
Now when the DHW is requested it sends the heat to the rads. I have changed the diaphrams in the diverter valve and this doesnt seem to have made any difference.
When the tap is turned on both microswitches are pushed closed is this normal?
Central heating seems to run fine just got no hot water now.
Could it be the heat exchanger? if so how would you remove this as i cannot see any unions is it possible to descale with a proprietory descaler if so which is brand recommended?
can i descale with it still in place put putting into radiator circuit?
Any help would be appreciated. thanks
