Hi All
I have erected a 2nd hand concrete garage. Because the site slopes, and I didn't want to get into above ground shuttering, I built a 9" thick wall and put the garage on top of this. I'm now ready to add the floor. I will put down MOT subbase and compact, then add DPM. The floor will come 1" up the inside of the garage walls, preventing water running down the driveway and into the garage, or from seeping under the walls.
My question is, how much work is it to pour the floor. I was thinking of using pump grade concrete - kind of self levelling, and the extra fine material they add should allow a nice smooth finish. I've never worked with this type of concrete before (I'm a DIYer), and I need about 4m cubed (5.6m square floor). I'd like a really smooth finish to make the garage easier to work in.
Does this type of concrete self level well? Do I still need to draw timber across it to make it flat? I don't have much space to work, as the garege walls are already up... And for a smooth finish, is something like a long handled easy float (from Brandon hire say) the way to go?
After laying, what's the covering up procedure for curing? Immediate, or do I leave it a few hours for the surface to dry before putting some PVC sheet over?
Thanks for any advice
Tony
Tony
