Does anyone have a copy of the user manual for a Power Devil table saw - PDW5012PB - 10" blade. I have just purchased one from ebay and need to strip it down to clean it properly.
I doubt if the manual would be of much help here, but if you turn the machine over you can usually access what you need.
The blade is encased in its own metal box, usually with a vacuum take off point incorporated.
From the table top, there's often a removable plate which allows you to access the blade arbor once you've taken it off. Lock the blade with a bar through its teeth to get purchase on the arbor nut.
John
Thanks John for the advice it will be extremely helpful and I really appreciate you taking the time to assist my search. I would still desire getting my hands on a manual as they generally help in contacts etc. and spare parts. Cheers, David
