power flush
1 Mar 2006
Tyne and Wear
Hello,
How do I know as a layman, if my central heating system needs a power flush.
I have a combi boiler and a micro bore heating system.
I have a 3 year old Baxi combi boiler which was fitted by a heating engineer. He did not flush the system when the boiler was fitted and I have since had a new heat exchanger fitted to the boiler.
This was done by British gas, as I had a loud whine coming from the boiler when the central heating started up from cold.
The original heat exchanger did appear to have a lot of sludge in it when the engineer flushed it out with water.
The whine from the boiler has since disappeared but I still have a whine from the heating system.
I have been advised by British gas to have a power flush.
Please any advice would be appriciated.
regards Mick Foster
best to pay someone else for a second opinion then decide whether you need it flushed
Did the whine last for about ten mins on cold start up. The baxi guys who say that has nothing to do with dirt but gas pressure too high.
you could always give it a clean yourself, will cost you a bit of time, plus about £15 for the chemical cleaner, the same for inhibitor when you've finished, and, if you can afford it, about £100 for a Magnaclean on the return to capture sediment in future.
Fairly straightforward DIY job.
The noise did disapear after 10 - 15 mins but I must admit after the heat exchanger was changed, I do not have the problem.
The engineer may have adjusted the gas pressure, after fitting the new heat exchanger but I could not say.
