Hi all,
In a couple of weeks i'll be installing a wired burglar alarm in my house, I don't think it matters but the model is a sterling 10 anyway.
In the instructions it says 'connect the unit to a single pole, unswitched, 3-Amp fused spur using 0.75mm2 cable'
The main unit is going to be in a small cupboard well out of the way upstairs in my house, and there is already a single socket inside the cupboard just below where i plan to mount the unit.
My question is: can i just put a 3-Amp plug on the 0.75mm2 cable and simply plug it into the socket or should i really run a fused spur from this nearby socket?
I know exactly how to run a spur but it would be so simple to use a plug and it's not like it can be turned off by accident or anything.
Thank you for any replies, they are much appreciated...
