Have 2 key cutting machines to power - (230v .20kw each)
need to install bright (spot) type lights x 2 over my workbench
Need to install general but bright interior lighting.
Need 1 x socket for power tool battery charging (18v Li - ion 2.4 a/h )
(poss 3 x sockets as for key machines too)
Looked into inverters and seems expensive and a lot of work with wiring and extra batteries and chargers and so on.
Now the lighting I assume I can get 12v spots and general lighting and just wire them into the internal lights in the back of the van, just fit a switch so I can have on what I want and off when not required.
What to do about the 3 x 230v supplies ?
I know halfords etc sell power packs for jump starting and so on, but surely the batteries in these are just for that - ie a heavy drain for a short time ?
I am looking for sustained drain that wont wreck the battery if it gets too low.
I know some of these come with inverters built in, if I can find one with a
high a/h leisure type battery would this power my key machines for any length of time ? What size of inverter would need to be built in ?
The Halfords type only seem to have 17 - 20 a/h batteries which seems not a lot to me.
Only one key machine would be in operation at any one time, the lighting would be on when working in the van day or night.
At times I have no access to external power / extension lead from customer, so I also have a 3000w generator for emergency use, which has no 3 pin sockets but one 110v and one 230v round socket.
How would I set about using this to connect to my sockets in a safe way if required ?
Gerry
Gerry
