Power max loosing pressure
7 Dec 2005
My IMI powermax keeps loosing its pressure, from 1.5bar - 0 in 12 hrs. I have checked all rads for leaks and there is nothing leaking through the ceiling. I have changed the pressure release valve but still the same. There is no hissing or water around the boiler. HELP...
the waters got be going somewhere stick a pot under the overflow pipe to see if it fills up ;) if it does its more than likely your expansion vessel causing the pressure to get too high and release the water outside ;)
