power shower air in system
10 Jan 2016
OK I've got the surrey flange on my cylinder going to the pump (MIRA) which feeds 2 showers, pipes run up into the loft then down to the showers which work fine,but still get air bubble build up occasionally which makes the pump pulse when not in use until i run the shower until air clears. What can i do Help? is there a automatic air valve i can fit in the highest points?
Tim
