Can someone help me here please.
I get major problems with air in my power shower system interrupting the hot water supply. The pump also 'surges' i.e. switches on & off without the shower being run. The problem is worse when the shower hasn't been used for a few days, the air seems to build up.
The problem is relieved by turning off the power, removing the shower head & running the system until the air is purged.
Heres the spec.
Watermill SS70DLV shower pump
Standard open vented indirect sytem with standard copper hot water cylinder
The pump is fed by 15mm pipe via a surrey flange from the cylinder and is situated on the floor next to the cylinder.
The shower head is in another room, same level but approx 5metres away. This is fed by 22mm pipe from the pump to the shower mixer.
Any ideas gratefully received.
Heres the spec.
