Hi all, hope you can help...
I am currently thinking of installing a power shower in the bathroom and after reading this website i think i've got a "rough" idea of how to do this (hopefully!).
What i've got at the minute is a cheap shower hose coming off the bath taps which isn't very good and pressure is very poor. I'm hoping a power shower will solve this.
The cold water feed to the bath taps comes from the tank in the loft. The hot water comes from the hot water/cylinder tank in a cupboard in the bedroom. The hot water tank is approx on the same level as the shower head which could explain the lack of pressure/head? I suppose i could always lift/relocate the hot water tank into the loft?? is this viable/recommended?
Ok, im thinking of getting a power shower and coming off the pipe coming out of the top of the hot water tank/cylinder with 15mm copper pipe to the pump located somewhere in the loft and then branching off one of the pipes from the cold water tank with 15mm to the pump. Then both hot and cold pipes from the pump to the shower with 15mm copper pipe.
Is it easy enough to wire the electrics for the pump also?
Any advice will be gratefully received.
Many thanks,
Mark
Many thanks,
Mark
