Power Shower Problem
2 Feb 2006
I have a power shower fed by a Monsoon 3.0 bar Twin pump, the pump is around 4 years old and the shower has always worked okay until the last couple of days. Water out comes out normally when the shower is first turned on but after a few minutes it reduces until there is just a trickle coming out, the pump keeps going as normal. Has anybody any ideas what could be the problem.
Regards
kevski
Strange does this still happen when you turn the shower valve to cold ?
if yes obvious one check cold storage tank has water, could be muck in the inlet.
anything dropped into your tank in the loft...like insulation or similar...causing a "floating" blockage
what like a turd.
