Can anyone advise on the route that power shower pump outlet supplies can be run ?
I am going to fit / locate a power shower pump in the cylinder cupboard, which is in an ideal location for the cold water tank supply to drop down and the hot supply to be taken from the cylinder via a York flange.
But the shower is located across the hall (1.5 meters). I.e. I will either have to go down from the pump and under the floor and then up to the mixer valve OR go directly up to the attic and then drop down to the mixer valve.
Is there an issue with either dropping down from a pump outlet and then back up to the mixer OR going up from the pump and then dropping down to a mixer.
My question relates to the discharge / outlet side of the power shower pump ?
Ynusmon
Ynusmon
