Hi all, I'm looking to upgrade the shower in my loft room ensuite, it's a (dead and very) old Mira event power shower fed by 15mm pipes. The shower is currently located a floor above the hot water cylinder, and is either level/just below the cold water tank in the loft room cupboard.
Can I replace this setup with a new mixer shower but fit a standalone pump under the bath? Or will this cause problems as the pump isn't next to/at the bottom of the HWC? I'm hoping as it already has a pump at that height (albeit not a standalone one) that it won't be an issue to go to this different set up.
Sorry if I'm being really thick and this is on the forum somewhere but I couldn't find it easily from searching!
If it is possible to go this new set up, I am assuming I could just add a pump to the existing 15mm hot and cold inlets and use the old Mira power shower wiring to power a new pump that would sit under the bath
Thanks!
Thanks!
