I am looking to install a thermostatic mixer shower in a ground floor room about 3 metres from the hot water tank. Do I need to fit an external pump to achieve a good pressure or will the fact that it is on the ground floor give me adequate pressure. The cold water tank is in the attic. Would I also be able to break into existing hot/cold pipework or would I need to run seperate feeds
