POWER SHOWER
27 Jul 2007
Northamptonshire
HI, FITTING POWER SHOWER.........SHOWERFORCE 1500XT...... HELP WITH THE SIZE OF ELECTRIC SUPPLY CABLE..2.5MM? 6MM? 10MM? JUST STATES; CONNECT TO 230/240V SUPPLY FROM RING MAIN, USE 30 A RCD SWITCH 3A RATING........
"USE 30 A RCD SWITCH 3A RATING........"
If you look carefully it will probably say "use a 30mA RCD Switch 3A rating . . . . ."
