can i use my current hot and cold water supply from my bath to fit a power shower. by t'ing off.
will i be able to use the bath as the same time as the power shower?
any help will be grand.
thanks for the rapid response but what do you suggest i do instead do i have to run new pipes, hot from the cylinder and cold from the cold tank in the loft?
alos is it ok to gain an electricity supply from the ring using a junction box?
cheers for the help.
