Problem:
We have a refrigerated trailer which needs power to it to keep it cold when it isn't hooked up to a cab.
The trailer is approx 25m away from the building, and stays there all week. Until a Friday when an empty tailer comes and the full one taken away!
The 'easiest' option is a long extension protected with a RCD. But I cannot see this being the right way to do it!! Where the trailer is parked, it is a working yard so protection to the cable is key! Also protection to the user when the connect/disconnect the plug.
From Section 717 I can see that a TN-C-S system cannot be used, as it won't be monitored all the time, or used by a skilled person. What would be the best system to use?
Any obvious ideas other than burying or suspending the cable?
Or will it be ok running an extension to the tailers if it has correct protection?
Thanks a lot
Thanks a lot
