- Joined
- 13 Aug 2013
- Messages
- 4
- Reaction score
- 0
- Country
Just purchased and fitted new set of decking lights. The decking is approx. 12m from the house (nearest power supply). Unfortunately the transformer is on a short-lead so will not streach to house. I therefore need to run a power cable from the house to the decking and connect. Any ideas what type of outdoor cable would suit? I prefer to use conduit-pipe to run at base of my fence-panels. The connection to the house could either be a simple hole drilled thru garage-wall or I could install an outside socket. The deckling lights are only used very occasionally so don't see need to bury cable beneath ground. Thanks
