Please advise:-
I am considering providing power to my shed, 15 metres from the back of the house for lighting and use of no more than 1 power tool (drill e.g) at a time. and am looking at 2 options:-
1.I have 2 spare fuseways and intend to use 1 for this. From a (30a)fuseway I intend to run a length of 2.5mm cable via RCD to the back outside wall and connect in a joint box to SWA cable and run this to the shed to a 2 way consumer unit, 1 for a double socket & 1 for lighting. At the risk of sounding stupid! would this suffice and does my proposal come under Part P? If not feasible, please advise.
OR
2.Use the armoured cable and connect it to the two way consumer unit in the shed and wire up the lights and socket etc as above. The other end of the armoured cable, instead of wiring it up to the spare fuseway in the consumer unit, terminate it into an adaptable box, then use some three core flex and connect the flex to the armoured cable using a connector block, ensure that I use glands and connect an earth lug from the gland to the earth in the connector block (an additional earth as well as the normal green/yellow earth wire) Then run a piece of flex and put a rcd plug on the end of it thus hopefully avoiding Part P?
OR
