Apologies if this has been asked before. My house has two ground floor rings, today the RCD tripped and would not turn back on. I have identified which ring is causing the problem and turned its MCB off. The RCD now turns back on. I have now unplugged everything on that circuit (mostly kitchen) and turned all the sockets off and removed a fuse from the cooker hood spur. I am sure there is nothing left plugged in but still can’t turn the MCB without the RCD tripping. If I can’t work it out I’m going to have to run a long extension lead to the fridge and call an electrician . Any suggestions welcome.
