I have a powercraft pressure washer bough from ALDI around 8 years ago.
The pressure hose split at the connector to the high pressure outlet.
I couldn't find anyone supplying replacement hoses, so having read that it was the same as the Karcher, I bought a Karcher push fit adaptor and hose. The problem is it doesn't fit
Having taken the washer apart, the pressure outlet elbow has a 22mm external diameter (it has a Karcher part number 9.036-307 which seems to be right).
The Karcher push fit adaptor seems to fit a fitting with an external diameter of 20.6mm.
Can anyone tell me if 22mm is right for (earlier ?) Karcher models ?
Have I bought the wrong pushfit adaptor , if so is there a connector to connect it to a 22mm pressure outlet ?
Any help appreciated.
Chris
Chris
