powercraft router 3470
19 Oct 2011
Nottinghamshire
hi to all
i will say sorry now if i have put this in the wrong place as its the first time and i have only just signed up.what i am after is any info on a powercraft router 3470 the router works great but sorry to say no paper work with it and also none of the bits and bobs .so i am hopeing i can get help thro this web site .so if anybody can help me out please get in touch.
and thx for reading this
heeelllooo and welcome ghost1942 :D :D
are you saying the operating instructions for basic use or what the gadgets that come with it are for ??
thx to a kind person i have got the info book and i will print that out later but i am after where i can get the bits from like the parallel fence ruler ,parallel fence & the guide rod,
i dont use the the fences in normal operation i use a baton and clamps/nails/screws
95% off my router use is with bearings or under a table
i have 6 routers and cant remember the last time i used a bar/fence
thx for the info
i have got a workbench so could i fix it under it so that the cutter is thro the middle and use it that way
these are good value
http://www.rutlands.co.uk/workshop-...r-tables/DK2009/deluxe-full-size-router-table
you cannot use anything thicker than around 6mm-12mm before you start loosing capacity
this is because with a router cutter you have 1/3 the shank out off the collet[chuck] this is around 8mm so iff you surface is say 22mm thick 16mm off the cutter will not be above the surface
thx for the info looks aa nice setup but sorry to say way out of my price range
£2---------
you need a workmate with jaws wide enough 2 clamps to hold the fence and a nvr[no volt relay]
