I have been advised to powerflush my 10mm central heating microbore pipes
I had a little problem with radiators occasionally not getting warm downstairs , or cold at the bottom and warm at the top etc ,
A couple of times the downstairs were all cold until I switched the upstairs ones off and ran the heating.
I bled some and the water is very dirty, thought that system needed a bit of a cleanout and some inhinitor in .
Another problem I have is no drain valves on any of the radiators downstairs (I have one on my boiler ) and the radiators are all piped individually straight up .
So do you advise me to try the powerflushing ?
or fit a drain plug to each radiator to drain the system , then add x400 and then drain and add inhibitor .
Any advice would be very welcome regards Pete
